AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Drawing Property Setup
1 REPLY 1
rochestersignal
347 Views, 1 Reply
Once I have setup and completed the Drawing Properties information for each drawing in a Project can I use that information to create an index or export the information ( such as Description 1,2,3 & Sheet Number) out to excel?
1 REPLY 1
jalger
in reply to: rochestersignal
Hi RochesterSignal,
Sure you can.
Right click on the project and select "Drawing List Report".
Select "new report" (Since this is the first time your running it)
Select "Do All" to process all Sheets in the project.
After that a Dialog box will pop up.
In the Report Generator dialog select the options you need (Change Report Format, sort order, etc)
Next choose to place the report on the drawing, or Save to file (and in your case select the Excel format xls), or Print it Directly from the Report generator.
I hope this helps,
James
James Alger
(I'm on several hundred posts as "algerj")
Work:
Dell Precision 5530 (Xeon E 2176M)
1tb SSD, 64GB RAM
Nvidia Quadro P2000, Win10
”Boost
