Can we Get Sheet number of Particular Drawing using VB.net?
Can we access Autocad's Particular button Event?
Please Reply if you know?
Solved by rhesusminus. Go to Solution.
Yes, you can get the sheet number from the drawing.
It's stored, IN the drawing, in the WD_M block reference. Look for the SHEET-attribute.
What button do you want to check for an event on?
i saw that sheet attribute value,but no value in that..
If i Go to drawing properties,I can see the sheet number..
But in WD_M Block the sheet number will be empty..
How should i get sheet number of Particular drawing?
Please Find Attached Image File,I attached Drawing Properties and WD_M Block..
You have exploded the WD_M block. Hence, the attribute values are gone.
Do NOT explode the WD_M block.
Set ATTDISP to ON to see the WD_M block. Now you should see the sheet number in the SHEET attribute (when you double-click the WD_M block)
Set ATTDISP to NORMAL when you're done.
Yes I got it sir...
When creating or changing the sheet in AutoCAD Electrical, the Drawing name must also be changed..
Can we do that using vb.net?
You can give the DWGs whatever filename you want. Just remember to update the WDP-file with the new filename.
Open the WDP file with notepad to have a look at what it should look like.
I opened WDP file with notepad,I saw some values,
How Can i access that file through vb.net code?
My answer here must be "just google it". There are so many ways to open a text-file and read data from it in .NET
From that WDP file I got Drawing file Name..But i cant find Where is the sheet number?
In the WDP-file you willl only find the following information about a drawing:
The rest of the information you'll have to get fra the WD_M-block inside the drawings.
Thank You very much sir,Your comment are all very useful to me..
Thank you...
Can we get All Drawings from Active Project?
See answer in http://forums.autodesk.com/t5/AutoCAD-Electrical/Drawing-List/m-p/3791071#U3791071
