AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Drawing Properties
13 REPLIES 13
Message 1 of 14
kani_mca
1114 Views, 13 Replies
Drawing Properties
Can we Get Sheet number of Particular Drawing using VB.net?
Can we access Autocad's Particular button Event?
Please Reply if you know?
13 REPLIES 13
Message 2 of 14
rhesusminus
in reply to: kani_mca
Yes, you can get the sheet number from the drawing.
It's stored, IN the drawing, in the WD_M block reference. Look for the SHEET-attribute.
What button do you want to check for an event on?
Trond Hasse Lie
AutoCAD Electrical and EPLAN expert
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Message 3 of 14
kani_mca
in reply to: rhesusminus
i saw that sheet attribute value,but no value in that..
If i Go to drawing properties,I can see the sheet number..
But in WD_M Block the sheet number will be empty..
How should i get sheet number of Particular drawing?
Message 4 of 14
rhesusminus
Can you post a screen-shot of the Drawing Properties dialog, and the SHEET attribute of the WD_M-block?
Trond Hasse Lie
Ctrl Alt El
Message 5 of 14
kani_mca
Please Find Attached Image File,I attached Drawing Properties and WD_M Block..
Message 6 of 14
rhesusminus
You have exploded the WD_M block. Hence, the attribute values are gone.
Do NOT explode the WD_M block.
Set ATTDISP to ON to see the WD_M block. Now you should see the sheet number in the SHEET attribute (when you double-click the WD_M block)
Set ATTDISP to NORMAL when you're done.
Trond Hasse Lie
Ctrl Alt El
Message 7 of 14
kani_mca
Yes I got it sir...
When creating or changing the sheet in AutoCAD Electrical, the Drawing name must also be changed..
Can we do that using vb.net?
Message 8 of 14
rhesusminus
You can give the DWGs whatever filename you want. Just remember to update the WDP-file with the new filename.
Open the WDP file with notepad to have a look at what it should look like.
Trond Hasse Lie
Ctrl Alt El
Message 9 of 14
kani_mca
I opened WDP file with notepad,I saw some values,
How Can i access that file through vb.net code?
Message 10 of 14
rhesusminus
My answer here must be "just google it". There are so many ways to open a text-file and read data from it in .NET
Trond Hasse Lie
Ctrl Alt El
Message 11 of 14
kani_mca
From that WDP file I got Drawing file Name..But i cant find Where is the sheet number?
Message 12 of 14
rhesusminus
In the WDP-file you willl only find the following information about a drawing:
  • Filename
  • Drawing Description 1
  • Drawing Description 2
  • Drawing Description 3
  • subfolder-location
The rest of the information you'll have to get fra the WD_M-block inside the drawings.
Trond Hasse Lie
Ctrl Alt El
Message 13 of 14
kani_mca
Thank You very much sir,Your comment are all very useful to me..
Thank you...
Can we get All Drawings from Active Project?
Message 14 of 14
rhesusminus
See answer in http://forums.autodesk.com/t5/AutoCAD-Electrical/Drawing-List/m-p/3791071#U3791071
Trond Hasse Lie
Ctrl Alt El
”Boost
