AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Drawing List Report - Update Existing Fails (Sometimes)
8 REPLIES 8
Message 1 of 9
drathak
974 Views, 8 Replies
I am able to generate a drawing list pretty much as I like it, and have saved a .set file to keep that available.  But my problem is when I come back and need to update it after adding more drawings.  (Or maybe even just closing out the file and coming back.  Haven't actually checked that.)
After running a new report using the .set file, I go to put it on the drawing and the option to update the existing table is greyed out.  If I insert it somewhere else and then remove the old one and get the new one back in place, I can make changes and it will let me update the existing table.  But every time I come back to it after some period of time, I have to insert a new table every time.
Anyone know what might cause thast?  (ACADE2013 SP2, WIN7 64bit)
There should be a way to "Edit" the table and trigger an update of the data fro the project file/scratch database.
Joe Weaver
Principle Associate Engineer - Nashville Electric Service
P&C Committee Chair – SDS Industry Consortium
8 REPLIES 8
Message 2 of 9
Wheelie22
in reply to: drathak
When you insert the first table did you use the firrst or second option ?
When it works make a DWT of it.
Message 3 of 9
drathak
in reply to: Wheelie22
Pretty certain I used the first.
How would making a DWT of it help in updating it in an existing .DWG?  I mean I can see how that would make the next new index easier. (if the update works)
Joe Weaver
Message 4 of 9
Wheelie22
Not the existing.
The guy that set up AcadE here did it right, so when we insert the INDEX sheet DWT and do a update (AE command C:UPDATE-DRAWING-LIST) it always works !
Unless I get a -2 error than I have to restart AcadE or the PC (un expected feature)
If some one chaged the style, just delete the table and copy it from the DWT and it works again !
Unless....
Message 5 of 9
drathak
@Wheelie22 wrote:
Not the existing.
Unless....
Ok, I haven't been running THAT command, just running the "Drawing List Report" by right clicking the project in Project manager.  You very well may have just solved my problem.  Off to check!
Aaaans not finding that command.  Maybe an in-house LISP routine?
Joe Weaver
Message 6 of 9
Wheelie22
Its a lisp command but the same as you use, I only removed the drawing selection because we always want every drawing.
Message 7 of 9
drathak
What command does the LISP routine execute?
Joe Weaver
Message 8 of 9
Wheelie22
(defun C:UPDATE-DRAWING-LIST ()
    (setq QQ	       "dwglst.set"
	  QQQ	       "c:\\Users\\USERNAME\\AppData\\Roaming\\Autodesk\\AutoCAD Electrical YOUR VERSION\\R18.2\\enu\\Support\\User\\"
	  USE_SET_FILE (strcat QQQ QQ)
    ) ;_ end of setq
    (C:ACE_DWGLST_RPT_DBX
	(nth 5 (C:WD_PROJ_WDP_DATA))
	USE_SET_FILE
	t
    ) ;_ end of c:ace_dwglst_rpt_dbx
) ;_ end of defun
O...
Tthe C:WD_PROJ_WDP_DATA makes a list of your WDP data from the currend project, I only need the 5th entry.
And the C:ACE_DWGLST_RPT_DBX makes the report.
Message 9 of 9
Wheelie22
This is the -2 error :
========== Drawing 6 of 6 ==========
Searching BLOCK table for attibute "WD_TB". . .not found
Using title block attribute mapping file
O:\BT-Data\General\AutoCAD\AeData\default.wdt...
 processing . . .
 displaying . . .
Error: bad argument value: positive -2
After a restart of AcadE it works again !
”Boost
