AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Drawing list Report error
3 REPLIES 3
Melcsa
480 Views, 3 Replies
Hello, I have a problem Autocad Electrical 2011, when I insert Drawing List Report load the list of other previous projects
3 REPLIES 3
metal_pro2
in reply to: Melcsa
Do you do a full Project Database Rebuild before you Run the report?
When ever I find that reports are acting up like your problem I will delete the project database file ".mdb" and rebuild the project database. I find this solves most of the problems with Drawing lists , BOM, x-ref, etc.
Melcsa
in reply to: metal_pro2
The bug is on all projects, including the default instance of Autocad; like WDEMO and EXTRA LIBRARY DEMO.
I´ve uninstalled and installed the software and the error continues.
In fact,  the list adds more projects, because all that are were preloaded previously
I already clear *. MBD and it doesn´t work;  I think the error is some variable in the software of Autocad.
thanks
metal_pro2
in reply to: Melcsa
I had a Drawing list Report problem a few years ago and it ended up I had to delete the dwglst.set files and create new ones from scratch to get things to work.
Pat Murnen helped me out and I got it working
here is the link to the post
http://forums.autodesk.com/t5/AutoCAD-Electrical/Drawing-List-Report-messed-up/m-p/2048615/highlight...
”Boost
