Solved by rhesusminus. Go to Solution.
You should be able to do this via Import/export Data -> Import -> From Project MDB.
Did a quick test, and it worked as expected.
Make sure you make a COPY of the project database, and edit/import this copy.
Got it!
I had completely and utterly missed the drawing index in the COMPPINS table. I kept making the change in the wrong drawing index (1) and was increasingly frustrated when I didn't see it on my intended drawing (4).
Thanks!
