AutoCAD Electrical General Discussion
Active Contributor
krollenhagen
Message 1 of 5 (112 Views)
Drawing Config Default Values
112 Views, 4 Replies
11-20-2003 05:10 AM
Does anyone know what file I need to change so that the I do not have to change the drawing config settings with every new drawing that I create?
*Kemp, Steve
Message 2 of 5 (112 Views)
Re: Drawing Config Default Values
11-20-2003 09:23 PM in reply to: krollenhagen
The easiest way to do this for a project, so that
all new drawings in a project get the same configuration, is after configuring
the drawing to the way you like it, select the 'Compare Dwg and Prj
Settings' option.  Thi soption is found under the 'Electrical->Project'
pull-down menu or under the 'Config Drawing' flyout.
This command will allow you to compare the
differences between the current drawing and the project default settings and
change the project settings to match the current drawings settings.  Then
every new drawing created in this project will get these settings.
Steve Kemp
AutoCAD Electrical QA
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Does
create?
Valued Contributor
Lint
Message 3 of 5 (112 Views)
Re:
11-20-2003 10:10 PM in reply to: krollenhagen
If you want to perminantly set your config
default you may either manually edit the
WD_M block (this is the config block
that gets inserted on your drawings)
you are using, or set your config
in a drawing and then in REPORTS, go to
SWAP WD_M, UPDATE WD_M. (the instructions
are straightforward) This will give you
a default config for all your drawings
Lynne
Active Contributor
krollenhagen
Message 4 of 5 (112 Views)
Re:
11-20-2003 11:13 PM in reply to: krollenhagen
Lint-
Thank you for you help. I did want a permanent solution.
Keith
*Autodesk, Inc\
Message 5 of 5 (112 Views)
Re:
11-20-2003 11:44 PM in reply to: krollenhagen
A very common practice also is to create and use a
template drawing.  This is the process that is recommended and shown in the
training classes.
Sincerely,
Jared Bunch
Technical Support Specialist
Autodesk, Inc
Lint-
Keith
Manufacturing Community
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
