AutoCAD Electrical Forum
Drawing Audit issue.
6 REPLIES 6
sonny3g
469 Views, 6 Replies
Has anyone run into an issue with the Electrical Drawing Audit arbitrarialy moving wire numbers to other segments?  Below is a before screen capture.
And this is the after image.
Scott G. Sawdy
scott.sawdy@bluecoyotecad.com
6 REPLIES 6
dougmcalexander
in reply to: sonny3g
If the wire numbers were ever moved with plain AutoCAD move they were actually no longer associated with their original wire. Drawing Audit attempts to return these "orphaned" wire numbers to their original wire segment. Just one possibility that I thought about.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
sonny3g
in reply to: dougmcalexander
Nope, I completely re-created the wire networks and got the same issue.  The only thing I can think of is that the wire numbers are the same as in other wire ducts in this project.
To get around the problem so I could run the Active Drawing Audit, I had to open a new project called TEST-Junk, add the drawing, then run drawing audit on it in that project.  Then it cleaned up the drawing without moving the fixed wire numbers from the wire line segments I had placed them.
So far, this has only happend in one drawing.
Scott G. Sawdy
dougmcalexander
Obviously you had already tried deleting the project scratch database, right? When you get a head scratcher like that the first thing to do is exit AutoCAD Electrical and delete the project scratch database. Then restart AutoCAD Electrical. Sometimes a bit gets scrambled in the database.
Doug McAlexander
drathak
What does this do that AEREBUILDDB doesn't?  Just curious.
Joe Weaver
Principle Associate Engineer - Nashville Electric Service
P&C Committee Chair – SDS Industry Consortium
dougmcalexander
in reply to: drathak
Deleting the project scratch database forces AutoCAD Electrical to recreate a fresh new project scratch database.  Rebuild/Freshen only forces the software to read the drawings again and update.  That won't usually repair a corrupt database.
I run Rebuild/Freshen right after I have made some edits and I am going to immediately extract data, like for a report or for exporting to spreadsheet. Saving the drawings is supposed to write to the database but I have had situations where the database had not caught up to the drawings yet.  So to be sure, I run Rebuild/Freshen.  And I always choose Full Rebuild.
Doug McAlexander
sonny3g
I did indeed delete the scratch database, rebuilt the database and finally solved the problem by pulling each malfunctioning drawing (I had six total) into my TEST-JUNK project one at a time.  Then while in the test project I was able to run the drawing audit without mishap.
Just to make sure it was all okay, I removed the drawing from the test project, reopened the actual project and ran drawing audit on the same drawing.  It ran without mishap.  Obviously something got messed up in each of these 6 drawings that I was able to "fix" by auditing them one at a time in a blank project.
Scott G. Sawdy
”Boost
