AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Drawing 0.dwg?
2 REPLIES 2
sonny3g
374 Views, 2 Replies
Drawing 0.dwg?
I have never seen this before, but it is giving me fits now.  I don't have a 0.dwg and never have.
Scott G. Sawdy
scott.sawdy@bluecoyotecad.com
2 REPLIES 2
Icemanau
in reply to: sonny3g
You may have a corrupt project project database file...
Close ACADE totally.
Do a search for the <PROJECT FILENAM>.mdb
Delete this file once it is found.
Restart ACADE
ACADE will now proceed to rebuild the project database from the dwgs.
If the error still pops up, try doing a dwg audit on the complete project, followed by an electrical audit.
Regards Brad
Brad Coleman, Electrical Draftsman
sonny3g
in reply to: Icemanau
I think I figured it out.  I tried what you suggested Brad, then I got an error calling for _Yes.dwg instead of 0.dwg.  So, I did a little more fiddling about and discovered that I was selecting  Go To for a reference in surf that had no sheet associated with it.  If I select the same reference that includes the sheet that is just below it in the list then it was peachy and I went right to the sheet and reference.
Scott G. Sawdy
”Boost
