AutoCAD Electrical Forum
distrabution block
3 REPLIES 3
mikegoutier
323 Views, 3 Replies
distrabution block
(electrical 2010) (not a cad pro)
I am trying to use a distrabution block that is going to feed multiple switches and other components on multiple pages. I dont want to use to and from reference arrows. I would like to show the distrabution block numerious times using the same tag name but still have all connections made and a bill of materials work.
Is this possible? I was toying with the concept of using parent and sibling relationships, but couldnt figure it out.
any help would be great.
3 REPLIES 3
mikegoutier
in reply to: mikegoutier
CAN SOMEONE PLEASE HELP?
Insert regular terminal symbols but only assign the part number to the first symbol.  I've been doing it that way since 1997. Do not insert the strip using Terminal Strip Editor. Create a link in the footprint lookup database that points to the distribution block footprint. Or just insert the footprint and manually assign the strip I'D.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
that makes perfect sense thank you sir, i wish i thought of that.
”Boost
