I have my own DIN rail and Wireway blocks I made years ago before AcadE had
that function. I used the stretch block command to stretch the block after
insertion. I use DIN rail without holes so I have no problem with that, but
then lots of companies don't even show DIN rails or just show a rectangle to
represent it. I will attach the DIN rail block I use in case you might find
it useful. I just insert and stretch to fit. Edit like any other footprint
to add MFG and CAT. I also tag mine as DR1, DR2, DR3, etc.
wrote in message news:5876559@discussion.autodesk.com...
Thanks for making me aware of this extra benefit to the Stretch PLC Module
command!
There is one drawback however. If this method is used on DIN rail, it won't
update the holes. If I have to stretch a rail beyond a point where there
should be another hole shown, or shorten it to where a hole should
disappear, this does have that issue. Still, it's a great option to have.
I think we'll use a combination of both since we've gone to the trouble of
creating the footprints & modifying the menu & lookup database. I for one
would still like to see Dynamic Blocks in the DIN tool though, and don't
want to attempt to write a LISP routine myself if it's already in the future
plans for ACAD-E.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in
AutoCAD Electrical training and implementation support
Phone and
Web-based Support Plans AvailablePhone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please
Accept as Solution if I helped you.
Likes are also much appreciated.
