This may or may not help... but if you create a wire layer with the
substring "JUMPER" in the layer name, then these wire connections will
automatically be excluded from the From/To Wire report. For example, you
might create a wire layer called "14AWG-JUMPER-GREEN". These connections
should exclude from the report.
wrote in message news:4826973@discussion.autodesk.com...
> I use a lot of DIN rail terminals with jumper bars to distribute voltage
rails. These are often double or triple level types.
> So far I have worked around this problem by creating a special wire layer
called LV_BUSBAR (for example). I use this layer for the horizontal ladder
rails. Being a wire it gets numbered. I use the supplied "wire breaking"
terminals as a schematic symbol to represent the rail terminals on the
schematic. I have created my own rail terminal footprint symbols for the
wiring diagram.
> However, being a wire, the jumper layer appears as a wire on the wiring
diagram. Also, on the wire to-from list I end up having a numbered wire that
is not actually a wire or a number! This causes a bit of confusion for the
wireman.
> Actually I don't really need "ladders" as such on my schematic. I find
they constrict the schematic diagram layout.
> I am thinking of creating some new schematic terminal symbols that
represent connections to a positive, ground or other rail and dispense with
ladders altogether. These will look like commonly used schematic symbols. I
will assume that all terminals with the tag "TB1-" (for example) will be
physically connected and will be manually placed side by side on the wiring
diagram. Could (should) these be parent and child components?
> Any comments? Examples? Has anyone else got good ideas on how to tackle
this problem? This is such a basic thing I'm sure it must have already been
done!
> I know that there is a "Terminal rail builder" but I have no idea how it
works and I have not tried it. From earlier posts in this forum I believe
that it only does vertical rails (terminal strips) anyway. Don't know if it
does jumpers. My DIN rail are almost always horizontal.
> Sorry to go on - have a nice day,
> John
