You ca insert intelligent DIN rail using the DIN rail/Wireway tool on the panel layout menu. If you wan't the DIN rail to be dumb lines, just use the Special Explode command.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in
AutoCAD Electrical training and implementation support
Phone and
Web-based Support Plans AvailablePhone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please
Accept as Solution if I helped you.
Likes are also much appreciated.
