AutoCAD Electrical Forum
DIN RAIL COMPONENTS
4 REPLIES 4
342 Views, 4 Replies
DIN RAIL COMPONENTS
I have noticed when I use din rail on a panel and then put an ACE terminal connection on the din rail, the din rail hides under the terminal. How do I make it so the footprints I make do the same thing, and hide the din rail it sits over.
4 REPLIES 4
Did you use Black Box Builder to create you footprint?
dougmcalexander
It is done with a feature called wipeout. Check the AutoCAD help system for more about wipeout. Not the Electrical Help system but the F1 help.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
fastbackgt68,
I have a post on my blog site about this. Here are the links.
http://robstein.blogs.com/rob_stein_knowledge_cente/2006/02/footprints_that.html
and
http://robstein.blogs.com/rob_stein_knowledge_cente/2006/04/footprints_that.html
I hope this helps and if you have any questions feel free to email me.
Rob Stein
INCAT
www.robstein.blogs.com
went to ACE help and the blog helped also. Thanks for the assistance
Joe
”Boost
