AutoCAD Electrical Forum
DIN and DESC1-3
3 REPLIES 3
Nata_ly
418 Views, 3 Replies
DIN and DESC1-3
Hi! DIN again (it's popular now).
I need to make attributes DESC1-DESC3, Count and Unit visible. Yes, I can fill they and place in report, but there aren't listed attributes in "Edit atribute" window. There are only 3: P_TAG1, RATING1, RATING3.
How can I make they visible? I can't find a block too.
And the same issue with Enclosures.
Thank you!
3 REPLIES 3
rhesusminus
in reply to: Nata_ly
i.
If the bolck doesn't have the required attributes, the data is stored in XDATA on the symbol.
There is a tool convert XDATA to Attrbiutes, namely "Make Xdata Visible".
Have a look at this function:
Trond Hasse Lie
AutoCAD Electrical and EPLAN expert
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Nata_ly
in reply to: rhesusminus
This is actually what I need! Thank you! Smiley Happy
Nata_ly
And I've found the DIN-file.
C:\documents and settings\all users\documents\autodesk\acade 2013\libs\panel\wd_ptag_addattr_comp.dwg (for 64 XP).
Now I can simply add my attributes there.
”Boost
