Can someone please help me with finding out why my descriptions (Titleblock attribute names) are not showing when I try to update the descriptions?
It is only showing line 1, line 2, etc., rather than title 1, title 2, or whatever the attribute name is.
I mapped them into the .wdt file, and they did work at some point, but no mas.
I have included a drawing with the titleblock I am speaking of, as well as the .wdp, and .wdl
sparky
Basically, you need to put the required information into a file called default_wdtitle.wdl
To do this, you need to know the exact order in which the attributes are listed when you edit the titleblock. This is easy to find by using the DDEDIT command and clicking on the titleblock.
In this case, you would open up Notepad and type in "LineX=<whatever you want to call it>":
For example:
LINE1=Title 1
LINE2=Title 2
LINE3=Drawing Title 1
LINE4=Drawing Title 2
LINE5=Drawing Title 3
LINE6=Drawing File Name
LINE7=Drawing Set Revision No.
LINE8=Scale
LINE9=Location in Section
LINE10=Township & Range
etc
Once you have finished, save the file as default_wdtitle.wdl and put it in the same folder as the .wdp file.
It is very important that you follow this format all the way down.
NOTE: You have to put this file into the same directory as the .wdp file every time you create a new project file.
Good luck!
EDIT: In your specific case, try changing the name Hideaway.wdl to Hideaway_wdtitle.wdl
If that doesn't work, change it to default_wdtitle.wdl
Where are the files? ZIP them together if you can.
Well, you have to name the file either
<project>_wdtitle.wdl (<project> being whatever the project file name is)
or
default_wdtitle.wdl
Also, this file HAS to be in the same folder as the Hideaway.wdt file in order for it work.
Either version will work for the project.
I personally prefer using default_wdtitle.wdl because I don't have to rename that file with every project. It's a default, and it should work with every project that uses the same titleblock.
Also, you may have to turn off "hide extension for known file types" in Windows Explorer. The file MIGHT have TXT extension...
@rhesusminus wrote:Also, you may have to turn off "hide extension for known file types" in Windows Explorer. The file MIGHT have TXT extension...
I thought of that... however, the files in the zip file he attached in the first post have the right extension.
