Unfortunately, the children will follow the parent's description thus not allowing you to have different header descriptions. If each cable marker is a parent, then this will work, but if you have one parent and many children that need to be matched up to the column header, then it won't. I don't recall if there is a description override for child components but maybe someone from the Acade development group can respond with a solution or add this to the wish list.
