AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Delete block and replace script
7 REPLIES 7
Message 1 of 8
MTE Controls
4336 Views, 7 Replies
Hello all. Eric Here.
Looking to replace the existing TB with an improved one.
I am looking for help on writing a script to pick a block and erase (delete) it. Then I'll purge it out and replace it with a new one of the same name.
The purge and replace I have but it's the erase I am having problems with.
This is my purge:
;; PURGE BLOCK
;; EDIT "yourblockname" TO SUIT
_PURGE
_B
"yourblockname"
_N
_QSAVE
;END SCRIPT
This is the insert new one:
;;INSERT A BLOCK AT 0,0
_INSERT
"yourblockname"
0,0
;THE ABOVE 2 CARRIAGE RETURNS
;ARE REQUIRED
;Ortho Angle
0
_ZOOM
_A
_QSAVE
;END OF SCRIPT
Both work even combined, again it's the select a block and erase that I can not seem to get to work.
Thanks.
Eric.
7 REPLIES 7
Message 2 of 8
Peter_KSBE
in reply to: MTE Controls
Hi Eric,
Why don't you use the "Swap/Update Block utility wich is inside AE. You can swap or update for the entire project or on drawing.
Think you need option B "update a block"
Where do you find this. Well when you click and hold the "insert component" icon it is at the bottom end.
Peter
Message 3 of 8
MTE Controls
Hi Peter,
I'm looking for this function "Swap/Update Block utility" but do not seem to locate it. I'm running AcadE 2007. If this works that would be great.
Eric
Message 4 of 8
Peter_KSBE
See picture where to find it.
Like I told you it is at the bottom of the "insert component" flyout.
Message 5 of 8
MTE Controls
Thanks just found it. This will help alot.
Eric
Message 6 of 8
MTE Controls
For those following this thread and the "Title Block Update" here is a script that works but keep in mind it does not keep current "Values" nor "Scale". But with TB updater that is not mutch of a problem.
Have fun people:
;; FIND AND ERASE BLOCK
(setq ss (ssget "_X" '((0 . "INSERT") ( 2 . "yourblockname"))))
;; Find all blocks named "yourblockname"
(if ss (command "_.ERASE" ss ""))
;; PURGE BLOCK
_PURGE
_B
"yourblockname"
_N
_QSAVE
;; END SCRIPT
;; INSERT A BLOCK AT 0,0
_INSERT
"yourblockname"
0,0
;; THE ABOVE 2 CARRIAGE RETURNS
;; ARE REQUIRED
;; Ortho Angle
0
_ZOOM
_A
_QSAVE
;; END OF SCRIPT
Message 7 of 8
controlsgirl
MTE Controls, thanks for the post. I just wanted to simply delete a block and purge it so I used your script minus the add. Now I just have to find a good quick reference guide that shows me what "ss" stands for(and other similar code) and how it's used :). It doesn't look quite as simple as entering what I normally would type if I were typing commands.
Message 8 of 8
Look for AutoLisp help.
"ss" is the generic name assigned to the block and not an instruction; it is done on this line:
From the help file:
setq = Sets the value of a symbol or symbols to associated expressions
Hope this helps,
Stefan
”Boost
