AutoCAD Electrical Forum
Default text height
3 REPLIES 3
michellef
365 Views, 3 Replies
Default text height
How can I change the default text height for a project? I'd like all my line numbers, wire numbers, cross-references and block attributes to all be .07". What variable do I need to change and how?
Michelle
3 REPLIES 3
in reply to: michellef
Go under Component Misc, then Text Wizard. You can edit all
the attributes in a library from here (it takes awhile, and
it's a good idea to back-up the library you are changing)
Lynne
Lynne
Lint is correct. It is always a good idea to create backup's before you start anything that is going to make some major changes like this. There are many symbols that it will have to open, modify, save, and close. I think it is upwards of 1500 files, and therefore will take some time. This is generally a good thing to run while you go out or lunch. Also keep in mind that this is modifying the symbol library, so any drawings that have already been created, will not be affected. To update these, you can use the LIBRARY SWAP option under the SWAP BLOCK command. This can be found at: ELECTRICAL > COMPONENT MISC > SWAP BLOCK > "option B" LIBRARY SWAP I hope this info helps -- Regards, Jared Bunch Technical Support Specialist Autodesk, Inc "Lint" wrote in message news:12246506.1071682248414.JavaMail.jive@jiveforum1.autodesk.com... > Go under Component Misc, then Text Wizard. You can edit all > the attributes in a library from here (it takes awhile, and > it's a good idea to back-up the library you are changing) > Lynne
”Boost
