Lint is correct. It is always a good idea to create backup's before you
start anything that is going to make some major changes like this. There
are many symbols that it will have to open, modify, save, and close. I
think it is upwards of 1500 files, and therefore will take some time. This
is generally a good thing to run while you go out or lunch. Also keep in
mind that this is modifying the symbol library, so any drawings that have
already been created, will not be affected. To update these, you can use
the LIBRARY SWAP option under the SWAP BLOCK command. This can be found at:
ELECTRICAL > COMPONENT MISC > SWAP BLOCK > "option B" LIBRARY SWAP
I hope this info helps
Jared Bunch
Technical Support Specialist
Autodesk, Inc
"Lint" wrote in message
news:12246506.1071682248414.JavaMail.jive@jiveforum1.autodesk.com...
> Go under Component Misc, then Text Wizard. You can edit all
> the attributes in a library from here (it takes awhile, and
> it's a good idea to back-up the library you are changing)
> Lynne
