Can someone please point me to the DCL file that controls the "Insert/Edit Component" dialog box (see attached pic). It seems like I have gone through all the DCLs a couple of times and can not find.
Thanks in advance.
Jeff
Solved by Wheelie22. Go to Solution.
It's in here :
c:\Program Files\Autodesk\Acade 2012\Support\wds1ed.dcl
Look for the text Insert / Edit component.
Hi
I need help with AutoCAD Electrical 2013. When I pull the purchase bill of materials report, I got many item numbers repeated.
We have the 3 option to suppress the repeated items, that work very good.
The problem it's when I loaded the purchase boom report on the screen, I got to many line spacing inside the cells, where the repeated items were before. How can I clean up those cells before to pull the report on the screen?
There are something that I can add to the pur_pbom script to clean up the table automatically?
Thank!
Rick
Down near the bottom of the first page I provide a .lsp file that will get rid of the extra spaces.
http://forums.autodesk.com/t5/AutoCAD-Electrical/Tallied-Panel-BOM-list/td-p/3596908
