AutoCAD Electrical General Discussion
david_vji
Message 1 of 3 (234 Views)
database refresh
234 Views, 2 Replies
10-19-2011 04:09 AM
when I changs somthing in my drawings autocad dos not notes changes until i have
powerd autocad down an restarted
Sample: I delead a terminal and the number is in use un til I reload autocad
Best regards
David
testsubject
Message 2 of 3 (232 Views)
Re: database refresh
10-19-2011 04:54 AM in reply to: david_vji
It depends on how you deleted the component. If you used the Delete Component button then it should have updated the project database (assuming you are working in the active project). If you just erased the component using Autocad's erase function then the database is not updated. If you do this, you have to manually update the project database.
Bob Hanrahan
Ace User since 1998
david_vji
Message 3 of 3 (230 Views)
10-19-2011 05:00 AM in reply to: testsubject
I am working in activ project and I used deleat compoment
I have used AE for several years now and I have never  had
this problem until know
It is not just when I erase a compoment,
when a chanse somting in a compoment, signal refrences
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Manufacturing Community
