AutoCAD Electrical Forum
database refresh
2 REPLIES 2
david_lota
419 Views, 2 Replies
database refresh
when I changs somthing in my drawings autocad dos not notes changes until i have
powerd autocad down an restarted
Sample: I delead a terminal and the number is in use un til I reload autocad
Best regards
David
Tags (1)
2 REPLIES 2
testsubject
in reply to: david_lota
It depends on how you deleted the component. If you used the Delete Component button then it should have updated the project database (assuming you are working in the active project). If you just erased the component using Autocad's erase function then the database is not updated. If you do this, you have to manually update the project database.
Bob Hanrahan
Ace User since 1998
If this answered your question, please click on "Accept Solution"
david_lota
in reply to: testsubject
I am working in activ project and I used deleat compoment
I have used AE for several years now and I have never  had
this problem until know
It is not just when I erase a compoment,
when a chanse somting in a compoment, signal refrences
”Boost
