Yes, this call would launch the command that is used for the dashed link
lines but it would require selecting the components. I didn't find a way to
pass it the components inserted within Circuit Builder.
Pat Murnen
"Brad Coleman" wrote in message
news:6302346@discussion.autodesk.com...
This is the command as called by the toolbar button in 2008 Electrical
^C^C^P(if(not wd_load)(if(setq x(findfile "wd_load.lsp"))(load
x)))(wd_load);wd_complink
wd_complink actually calls the routine, the rest seems to check and load the
command file if it isn't already loaded.
Hope this information helps.
Regards Brad
"LTriska" wrote in message
news:6301257@discussion.autodesk.com...
Hi.
I would like to know how do I do a dashed line using circuit builder
command?
Note: Please, see attached.
Thanks.
LTriska
