AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Customized Symbols - Wires not breaking when symbol inserted
6 REPLIES 6
STEVENAR
548 Views, 6 Replies
I have customized my own block symbols and am trying to insert the symbols into a ladder, however the wires are not breaking. I have inserted my wire connections into the customised symbol. Can some please advise why the wires are not breaking.
Thanks & regards.
6 REPLIES 6
bholle
in reply to: STEVENAR
Is it possible to attach the symbol for us? And how are you trying to insert it into the drawing?
dougmcalexander
Be sure your wire connections are inline with one another.  The Symbol Builder has an audit function that will flsg such errors.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
Be sure also that the attributes X1TERM01(right side), X2TERM01(top side), X4TERM01(left side) and X8TERM01(bottom side) are used in the right place.
STEVENAR
in reply to: dougmcalexander
That worked. However I am now trying to insert a custom symbol with 6 wire connections 3 on the RHS and 3 on the LHS and again the wires are not automatically breaking. Is this possible?
Thanks for your help.
stefan.stamate
Be sure that you use different terminal numbers, see the picture below (this is the generic box with 4 terminals)
STEVENAR
in reply to: stefan.stamate
Does the spacing in the ladder need to correspond with the spacing between the wire connections? Also can a component like this be inserted into multi-wires which have been inserted separately and not as a ladder?
Thanks again.
”Boost
