AutoCAD Electrical General Discussion
Distinguished Contributor
STEVENAR
Message 1 of 7 (276 Views)
Customized Symbols - Wires not breaking when symbol inserted
276 Views, 6 Replies
10-01-2012 07:50 AM
I have customized my own block symbols and am trying to insert the symbols into a ladder, however the wires are not breaking. I have inserted my wire connections into the customised symbol. Can some please advise why the wires are not breaking.
Thanks & regards.
Active Contributor
bholle
Message 2 of 7 (268 Views)
Re: Customized Symbols - Wires not breaking when symbol inserted
10-01-2012 09:33 AM in reply to: STEVENAR
Is it possible to attach the symbol for us? And how are you trying to insert it into the drawing?
dougmcalexander
Message 3 of 7 (260 Views)
10-01-2012 12:07 PM in reply to: STEVENAR
Be sure your wire connections are inline with one another.  The Symbol Builder has an audit function that will flsg such errors.
Doug McAlexander
Independent Consultant/Instructor/Mentor specializing in AutoCAD Electrical, ecscad, and promis-e implementation
Web site: www.ECADConsultant.com
Phone: (770) 841-8009
Please Accept as Solution if I helped you. Kudos are also much appreciated.
Active Contributor
stefan.stamate
Message 4 of 7 (238 Views)
10-02-2012 06:45 AM in reply to: dougmcalexander
Be sure also that the attributes X1TERM01(right side), X2TERM01(top side), X4TERM01(left side) and X8TERM01(bottom side) are used in the right place.
STEVENAR
Message 5 of 7 (232 Views)
10-02-2012 07:15 AM in reply to: dougmcalexander
That worked. However I am now trying to insert a custom symbol with 6 wire connections 3 on the RHS and 3 on the LHS and again the wires are not automatically breaking. Is this possible?
Thanks for your help.
Active Contributor
stefan.stamate
Message 6 of 7 (228 Views)
10-02-2012 07:43 AM in reply to: STEVENAR
Be sure that you use different terminal numbers, see the picture below (this is the generic box with 4 terminals)
STEVENAR
Message 7 of 7 (224 Views)
10-02-2012 07:56 AM in reply to: stefan.stamate
Does the spacing in the ladder need to correspond with the spacing between the wire connections? Also can a component like this be inserted into multi-wires which have been inserted separately and not as a ladder?
Thanks again.
Manufacturing Community
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
