AutoCAD Electrical General Discussion
*Nate Holt
Message 1 of 1 (41 Views)
Custom wrapper around INS CIRC command
41 Views, 0 Replies
06-29-2004 06:50 AM
This issue has come up recently... user wants to insert a standard circuit and have the tags on the devices and terminals all carry a common, incrementing suffix value for each insertion of the circuit (ex: motor circuit). Here is a quick example of how this might be implemented: 1. Construct your standard circuit ".dwg" file with "fixed" tags ending in character "%". This character will serve as the place holder for the common suffix value passed to the insert circuit command. So you might have fixed tag "M%" on the motor symbol, "MS%" on the motor starter coil and on child contacts (child contacts would not have to be "fixed"), terminal numbers "A%", "B%"... on the various terminal symbols (not "fixed"), and so on. 2. Put a simple AutoLISP "wrapper" around the AcadE "INS CIRC" API call. A possible approach is shown below. Then, instead of launching the normal AcadE INS CIRCUIT command when you want to pop in a series of these incrementing circuits, launch the "wrapper" program instead. It prompts you for the "suffix" value and then proceeds to make it happen. (defun c:ins_circ_increment ( / suffix val ed en #lastent #newlastent newval) (setq circ_to_insert nil) (setq circ_insertion_xy nil) (setq options 0) ; 1's bit set=keep fixed wire numbers (setq suffix (getstring " SUFFIX value=")) (if (AND suffix (/= suffix "")) (progn (setq #lastent (entlast)) (c:wd_ins_circ2 circ_to_insert circ_insertion_xy 1.0 options) (setq #newlastent (entlast)) (if (not (eq #lastent #newlastent)) (progn ; assume that circuit successfully inserted. Now process ; the inserted circuit. Look for block inserts. (setq en #lastent) (while (setq en (entnext en)) (progn (setq ed (entget en)) (if (= (cdr (assoc 0 ed)) "INSERT") (progn ; block insert found. Look for TAG1, TAG2, TAGSTRIP attribute (setq val (c:wd_getattrval en "TAG1,TAG1F,TAG2")) (if (AND val (/= val "")) (progn ; Check last character for target flag of "%" (if (= (substr val (strlen val) 1) "%") (progn ; Yes, make the substitution (setq newval (strcat (substr val 1 (1- (strlen val))) suffix)) (c:wd_modattrval en "TAG1,TAG1F,TAG2" newval nil) ) ) ) ) (if (c:wd_getattrval en "TAGSTRIP") (progn ; hit a terminal (setq val (c:wd_getattrval en "TERM*")) ; get terminal number ; Check last character for target flag of "%" (if (= (substr val (strlen val) 1) "%") (progn ; Yes, make the substitution (setq newval (strcat (substr val 1 (1- (strlen val))) suffix)) (c:wd_modattrval en "TERM*" newval nil) ) ) ) ) ) ) ) ) ) ) ) ) (princ) )
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Manufacturing Community
