AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Custom Terminal Strips & Wire Numbers
2 REPLIES 2
854 Views, 2 Replies
I working on a project where I'd like to use our standard terminal strip representation in ACADE (see attached picture).
I've successfuly created the custom terminal strip and imported it into ACADE. My issue is the wire numbering. Ideally, I would like to display the wire number once, inside the terminal box with the remote ends of the wires on the left and right of the terminal block. Unfortunately I've not been able to figure out how to do this.
Anyone have any suggestions?
Thanks.
2 REPLIES 2
Icemanau
Using the TSE editor, it is possible to set up the wire numbers however you like.
In the attached screen shot, I've circled the section where you fill in the data for the wire number format.
The default pick list will give you and idea on how to set them up.
It is also possible to use some of the other replaceable paremeters within the wire number sequence.
Regards Brad
Brad Coleman, Electrical Draftsman
in reply to: Icemanau
Ah, I didnt realize you could manually input the parameters. Thanks!
”Boost
