Hello, I'm trying to create a custom symbol to use as a terminal.
GOAL: when doing a multiple insert of a custom terminal component from the icon menu, I want to create an editable terminal strip composed of what look like screw terminals in model view.
STATUS: I've tried modifying a round with terminal number from the model space into symbol builder to look like a screw terminal, inserting two diagonal lines and inserting it in the icon menu without altering anything else. When I try to create a terminal group, none of the "new" components allow me to open the terminal strip editor. When I look for some difference, I find that the LINKTERM attribute is not being automatically set when the "new" components are inserted.
My question is, is it possible to create/modify a symbol and use it to create terminal blocks/strips.
Solved by dougmcalexander. Go to Solution.
When you save your new, edited symbl, what do you name it?
The letters "DV" in a suggested symbol name are supposed to be replaced by the user with letters that match a table in the catalog lookup database. In the case of terminal blocks, the naming convention is different, as you have discovered. Normally, the 2nd and 3rd character of a symbol's file name directs AutoCAD Electrical to the apropriate table when you perform a Lookup to assign a part number. Normally the tables are named with two letters, such as CB for circuit breakers, CR for control relays, FU for fuses, etc. But for terminal blocks the table is named TRMS. This requires that a WDBLKNAM attribute be added to the terminal symbol with a value of TRMS. The WDBLKNAM attribute signals the Lookup function to disregard the block name and look at a different table, as defined in the value field of the WDBLKNAM attribute. The HT1 or HT0 etc. in a terminal symbol's file name instructs the software to process all operations against this device using subroutines that are intended for terminal blocks only. Just FYI...
Thank you. I'm wondering, does this relate to the cousin problem of creating original objects that are able to have parent-child relationships? Is the ability to have these relationships constrained to certain types of tables? In a less technical sense, when is it more appropriate to use multi-catalog rather than parent-child?
Thanks, that really answers my question. I don't want to be a drain, but I do have one more related problem... what kind of situation would obtain if I needed to create a custom symbol for a VFD card on one sheet, and another custom symbol for a different aspect of the same VFD drive on another sheet, showing its electrical hookups? If both symbols represent different aspects of the same part, then technically, I'm thinking, this would call for a parent-child relationship (same part for both). But this creates a headscratcher - how does one create a parent-child relationship between two created symbols? Does this get into the table value assignment techniques you mentioned?
That is exactly what I do for VFDs. The parent carries the primary controls termination points, any value settings I need and the child carries the motor connections. I do it that way so I can put more motors on a sheet and keep all of my low voltage on a separate sheet.
