Some of the symbols I have created in AutoCAD Electrical need to display what number component they are: for example, if I insert a Vacuum Pump, it will need to display that it is Vacuum Pump 1. Then if I add the same Vacuum Pump symbol, it will need to automatically show that it is Vacuum Pump 2.
Is there a way of doing this with Attributes without the use of TAG1 (this is already being used). At the moment I have used DESC2 and the user has to manually enter the number in the 'Insert/Edit Component' menu, but I need it to be automatic.
Any help you be amazing!
Liam
Here is the symbol to which the question is referring to:
This number needs to change according to how many of the same component are in the drawing, this also needs to be automatic and not manual (as it works now)
Any help would be amazing.
Thanks!
Liam
