Some of the symbols I have created in AutoCAD Electrical need to display what number component they are: for example, if I insert a Vacuum Pump, it will need to display that it is Vacuum Pump 1. Then if I add the same Vacuum Pump symbol, it will need to automatically show that it is Vacuum Pump 2.
Is there a way of doing this with Attributes without the use of TAG1 (this is already being used). At the moment I have used DESC2 and the user has to manually enter the number in the 'Insert/Edit Component' menu, but I need it to be automatic.
Any help you be amazing!
Liam
