AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Custom cable marker not cooperating with Terminal Strip Editor
6 REPLIES 6
SteveEE
463 Views, 6 Replies
I created a custom cable marker based off of the existing default cable marker block. Unfortunately, whenever I use the custom block, the terminal strip editor sees the cable marker as a device instead of a cable. Now all of the terminal blocks generated by the editor are incorrect. Is there any solution to this? I can get by with the default cable marker block but the hassle of going and changing the text attributes to match our standards is a considerable pain. Thanks!
Tags (1)
6 REPLIES 6
drathak
in reply to: SteveEE
Post a sample of your custom cable marker symbols.  What exactly did you change?  Did you add anything?  Did you follow the block naming conventions for cable markers?
Joe Weaver
Principle Associate Engineer - Nashville Electric Service
P&C Committee Chair – SDS Industry Consortium
SteveEE
in reply to: drathak
All I did in this case was change the text style and size.
drathak
Did you give them a different name?
Joe Weaver
SteveEE
What do you mean by a different name? The block name is HW_01 or HW_02.
When I was using the symbol builder to create the cable marker block there was no "cable" option so I had to choose "generic". The default name given to the block was HDV1_001, which I changed to HW_01 before saving.
drathak
I didn't see your attachments the first time.  The underscore is what is causing your problem.  Cable markers should be HW01 & HW02 rather than HW_01 & HW_02.
Have a look at this for help on naming conventions. Cable markers happen to be the first thing covered.
http://wikihelp.autodesk.com/AutoCAD_Electrical/enu/2012/Help/0266-Symbol_L266/0269-Library_269/0270...
Joe Weaver
SteveEE
Ah ha!
Thanks for the help.
”Boost
