Solved by drathak. Go to Solution.
Post a sample of your custom cable marker symbols. What exactly did you change? Did you add anything? Did you follow the block naming conventions for cable markers?
Did you give them a different name?
What do you mean by a different name? The block name is HW_01 or HW_02.
When I was using the symbol builder to create the cable marker block there was no "cable" option so I had to choose "generic". The default name given to the block was HDV1_001, which I changed to HW_01 before saving.
I didn't see your attachments the first time. The underscore is what is causing your problem. Cable markers should be HW01 & HW02 rather than HW_01 & HW_02.
Have a look at this for help on naming conventions. Cable markers happen to be the first thing covered.
