AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Custom block wire number question
6 REPLIES 6
503 Views, 6 Replies
I created a custom schematic block to show the wiring of a 12mm spiltter to use with a remote I/O block but am having problems when using adding wire numbers. The wire numbers will not flow thru the block unless I explode the block. Did I miss something in the block creation that is doing this?
thanks
Jason
6 REPLIES 6
Icemanau
You have to change the X?TERM## numbers to match. The numbers to match would be the ##, not the ?.
As you can see in the JPG, after I changed the numbers to match, the wire number (aqua) fed through to the copies (dark green).
I've also attached the updated block so you can see what changes I have made to it.
Regards Brad
Brad Coleman, Electrical Draftsman
controlsgirl
in reply to: Icemanau
I tried this with a symbol but ACE 2012 is still changing the wire number. Is this a glitch in 2012?
Icemanau
in reply to: controlsgirl
Did you use an old version of the block in that dwg before you tried the updated version?
If so, you need to either use the SWAP/UPDATE tool to update the existing blocks or purge the blocks to remove the saved reference.
Regards Brad
controlsgirl
Unfortunately I did update it 😞
jseefdrumr
I've had a couple of instances where SWAP/UPDATE didn't actually update properly. Can you delete the block, use PURGE on its definition, and then try again? If that doesn't work, can you post a copy of the block?
Jim Seefeldt
Electrical Engineering Technician
controlsgirl
in reply to: jseefdrumr
It worked because I opened up the block editor and looked at the component and it had the changes that I made. I am using ACE 2012 and it has been giving me problems with number changes. For example, it will change the wire number if a component does not have an underscore for the 4th character of its name.
”Boost
