AutoCAD Electrical Forum
CTB files missing and cannot load them
1 REPLY 1
1893 Views, 1 Reply
My IT department just loaded AutoCad Electrical 2015 to my computer (old version was AutoCad Mechanical 2014).  All of my Plot styles are now missing (the standard 7 or 8 ctb/stb files that AutoCad provides).  The button next to the Plot style dropdown menu is also not available.
I have tried STYLESMANAGER command, but it only opens "My Documents", which doesnt seem right....
Does anyone know where the ctb & stb files normally reside within the Autodesk folder?
1 REPLY 1
rhesusminus
Normally, they should be located around here:
C:\Users\USERNAME\AppData\Roaming\Autodesk\AutoCAD Electrical 2015\R20.0\enu\Plotters\Plot Styles
You can change this location in AutoCAD. Type config at the comand line and have a look here
Trond Hasse Lie
AutoCAD Electrical and EPLAN expert
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Tags (1)
”Boost
