I do single-lines with AcadE by manually making the single line symbol match the tag of its 3-line equivalent. You will get an error popup but you can ignore it or turn off real-time error checking. By setting it up this way the catalog assignment, description text, etc. are all bi-directionally maintained. Of course I just insert the 1-pole circuit breaker symbol to be a single-line equivalent of the 3-line version. I thought if Adesk would give us a new kinf od WD_M block that designates a drawing as being a single-line drawing, then real-time error checking would not think it is an error when I have duplicate tags. I thought it would be nice if, to assign the tag to a single-line symbol, we could get a list of all 3-line device tags within the component family and vice versa if we are creating a 3-line drawing from a single-line. In other words, if I am on a 3-line drawing and want to reference the 1-line equivalent symbol I would click a button for a list of 1-line symbols of that family type, with INST, LOC, TAG, description lines, etc. and select the symbol I want to associate as a 1-line equivalent. Of course also being able to do this the other way around would be nice. AcadE already allows you to have a schematic symbol, a pneumatic equivalent, and a panel layout symbol that are all three seen as one device without duplicate tag error warnings, but it doesn't yet support a single-line peer of components in the same fashion. Maybe in the future huh?
Note: I actually have a project with pneumatics, single-line, 3-line, and panel layout with multi-directional updates possible. The WDTAGALT takes care of the pneumatic to schematic link, the 1-line and 3-line are manually linked by duplicating the tag, and of course the panel symbols already link intelligently. The only devices that AcadE doesn't currently link up without thinking you have duplicated tags is the 1-line diagram because this is not a native function in AcadE.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in
AutoCAD Electrical training and implementation support
Phone and
Web-based Support Plans AvailablePhone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please
Accept as Solution if I helped you.
Likes are also much appreciated.
