PaulUla
There is also the ability to tell projects not to use certain wire numbers,
which would help you to accomplish the continuation of wire number from an
existing project. For example, if the existing project used wire numbers 1
through 298, you could tell the new project not to use those and it would
start with 299. You should be able to find this option in the project
settings. Let me know if you need any help locating it.
Good luck and thanks!
Jared (Autodesk, Inc)
wrote in message news:5144720@discussion.autodesk.com...
Thank You
