Hi LTriska.
I get the same problem here.
The solution is to use comma (,) instead of a dot (.) as a decimal separator
for the values in the "X-Y Grid Setup" dialog.
Haven't tested any special, but this might be a regional thing. Here in
Norway we use comma as the decimal separator, but in AutoCAD we use dot as
the decimal separator. I think that AutoCAD Electrical should use the same
as AutoCAD (dot) as the decimal separator for all values/dialogs.
THL
Trond Hasse LieAutoCAD Electrical and
EPLAN expert
Ctrl Alt ElPlease select "Accept Solution" if this post answers your question. 'Likes' won't hurt either.
