AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Cross reference setting
2 REPLIES 2
817 Views, 2 Replies
Hi there,
I am using ACE2010. I set cross referencing in table format, and then I decide to change it to graphical format. Now, I have 2 question:
1- why the cross referencing  table is too large & how can I resize it automatically project wide?
2-when I switched to graphical format, C/O contacts are shown in NO & NC type separately (just like table format). See attached photo... & how can I modify it?
Best
2 REPLIES 2
dougmcalexander
The table size comes from the Table Format parameters for the drawing.  The tables are derived from the standard AutoCAD table object settings.  Click Table Style under the Annotations submenu of the Home tab.  You can Modify text, border settings, etc.  The graphical format just removes the table.  This is normal.  It's about the same as using the Text cross-referencing  but instead of NO and NC you see actual symbols for NO and NC.  The example you posted is 4PDT Form-C (i.e. Omron or Idec ice-cube relay).  Your relay is using the default graphical xref symbol for Form-C.  The default graphical symbols are shaped fonts.  You have the option under Drawing Properties>Cross-References>Setup to Edit Symbol Mapping and use an actual library symbol for the cross-references.  See the attached screen capture from my IEC training course.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
in reply to: dougmcalexander
Hi Doug McAlexander
    I relized that in your attachment the cross-reference table hadn't the title and header,could you show the setting to hide the title and header automatically?
”Boost
