Hi there,
I am using ACE2010. I set cross referencing in table format, and then I decide to change it to graphical format. Now, I have 2 question:
1- why the cross referencing table is too large & how can I resize it automatically project wide?
2-when I switched to graphical format, C/O contacts are shown in NO & NC type separately (just like table format). See attached photo... & how can I modify it?
Best
The table size comes from the Table Format parameters for the drawing. The tables are derived from the standard AutoCAD table object settings. Click Table Style under the Annotations submenu of the Home tab. You can Modify text, border settings, etc. The graphical format just removes the table. This is normal. It's about the same as using the Text cross-referencing but instead of NO and NC you see actual symbols for NO and NC. The example you posted is 4PDT Form-C (i.e. Omron or Idec ice-cube relay). Your relay is using the default graphical xref symbol for Form-C. The default graphical symbols are shaped fonts. You have the option under Drawing Properties>Cross-References>Setup to Edit Symbol Mapping and use an actual library symbol for the cross-references. See the attached screen capture from my IEC training course.
Hi Doug McAlexander
I relized that in your attachment the cross-reference table hadn't the title and header,could you show the setting to hide the title and header automatically?
