hello
I'd like to know if it is possible to cross-reference a terminal which is the electrical diagram and represents that it is in a terminal (which is represented with the graphics function) because we want to quickly find the terminal in the terminal diagram I use autocad electrical 2010
thank you your help
When graphical terminal strips are inserted using the Terminal Strip Editor, a link is created between the graphical terminal and its schematic equivalent. This link allows for surfing and bi-directional updates.
the problem is that the paper can be found from the terminal create with the editor of terminal, the terminal on the electrical diagram.
as if there was a cross reference of a coil (terminals graph) and contact (terminal in electrical diagram) I do not know if I'm making myself clear ...
thank you for your help
Attached are a screenshot of what I would like if possible
