AutoCAD Electrical Forum
cross-reference between terminal
2 REPLIES 2
kcnarf38770
371 Views, 2 Replies
hello
I'd like to know if it is possible to cross-reference a terminal which is the electrical diagram and represents that it is in a terminal (which is represented with the graphics function) because we want to quickly find the terminal in the terminal diagram I use autocad electrical 2010
thank you your help
2 REPLIES 2
When graphical terminal strips are inserted using the Terminal Strip Editor, a link is created between the graphical terminal and its schematic equivalent.  This link allows for surfing and bi-directional updates.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
kcnarf38770
in reply to: kcnarf38770
the problem is that the paper can be found from the terminal create with the editor of terminal, the terminal on the electrical diagram.
as if there was a cross reference of a coil (terminals graph) and contact (terminal in electrical diagram) I do not know if I'm making myself clear ...
thank you for your help
Attached are a screenshot of what I would like if possible
”Boost
