Hey guys,
So I am trying to create a symbol for a fused terminal block. I found a symbol in the library that I want to use but I can't figure out how to edit the symbol so that it won't change the wire number when I insert it.
Any suggestions?
Okay nevermind! I figured it out. I will post my solution in case someone else has the same question in the future.
When you first select symbol builder, you have to select the objects, pick insertion point, etc. Well you also have to specifiy what the symbol is and what type. For the symbol option I chose "horizontal terminal" and for type I chose "terminal with wire number". That fixed my problem with the wire number changing.
Note that I also had an issue with the symbol not behaving like a symbol at all when I saved everything and inserted it. This was due to the fact that I completely changed the symbol name when saving it. I think it's the first four letters that are most important because auto cad uses that to determine what type of symbol it is. So when you save your symbol be sure to leave the first four letters as they are.
Hope this helps someone at some point.
Later!
I would suggest looking over the Help topic on Library Symbol Naming Conventions used by AcadE. You can find it in the Help at Symbol Libraries > Library Symbol Naming Conventions > Overview of symbol naming conventions or the same topic on the wiki at http://wikihelp.autodesk.com/AutoCAD_Electrical/enu/2012/Help/0266-Symbol_L266/0269-Library_269/0270...
One item in particular regarding terminals -
Thanks I will definitely check that out as I want to create a distribution block that will not trigger a change either.
The wire number change is triggered by the symbol name. Here are the rules to follow when creating and naming a schematic symbol in AutoCAD Electrical (pulled from the Help topic http://docs.autodesk.com/ACAD_E/2014/ENU/filesAcadE_UsersGuide/GUID-EC107A26-54F7-4F2E-85AC-82893AF7...
The red text is critical to determine whether you want a wire number change across the symbol or not.
Schematic components such as relays, switches, pilot lights, and discrete motor control devices (but not PLC I/O symbols) follow this naming convention:
Important - Do not use "HH", "HV", "VH", or "VV" as the first two characters of a symbol block name.
Hope this helps,
Pat
