AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
create multi-sheet .pdf from project plot command
8 REPLIES 8
Message 1 of 9
929 Views, 8 Replies
Can i use the ACADE "plot project" command to create a multi-sheet .pdf file (using the DWG TO PDF.pc3)? i can't even get it to create a single sheet .pdf.
is there another regular ACAD tool i should look into, like SheetSet Manager?
8 REPLIES 8
Message 2 of 9
You can use the publish to dwf command. Then publish to a multisheet dwf. Then open the dwf and print to pdf printer.
Alternately you can publish to a pdf printer that collects all the pages and that allows you to combine them to a multisheet pdf.
Sven Kloeck
Electrical Network Design
Message 3 of 9
mgalicki
I need my PDF's individual!
Can I generate individual pdf's from SSM?
Everything in existence was first an Idea
Autodesk Plant 3D Premium 2019
Autodesk MEP 2019
HP 3.2 Ghz CPU 16 ram
1TB 7200 rpm SATA 6Gb/s hard drive
2GB DDR3 NVIDIA GeForce GTX 680ti
HP 2311x 23" LED Monitor
Message 4 of 9
ronbotkin
Try using the Publish to DWF instead of plot.  You select the drawings, select which tab you want to print and UNSELECT Run Publish in the background.  Top left select Publish to: PDF.  Under publish options be sure to set the Location to where you want the file to go.  For type: select Multi-sheet file then change any other settings you want and hit OK.  Select Publish and it should make the PDF.
Message 5 of 9
mgalicki
in reply to: ronbotkin
This method still creates (1) PDF with all the sheets in it.
I need separate PDF's created for each sheet.
Autodesk MEP 2019
Message 6 of 9
ronbotkin
in reply to: mgalicki
Just select single sheet and it will do each one seperately.
Message 7 of 9
mgalicki
Well it worked this time?
It hasn't in the past.
Thanks ronbotkin
Autodesk MEP 2019
Message 8 of 9
ronbotkin
Glad it helped.
Message 9 of 9
mgalicki
For sheet set publishing, set the variable "publishcollate" to <1> for all sheets to be in (1) pdf file.
And set the variable "publishcollate" to <0> for all sheets to be individual files.
Hope this helps someone.
MGEE
Autodesk MEP 2019
”Boost
