When copying drawings from one project to another is it possible to carry all drawing properties, ie. Description attributes and Drawings numbers as these fields become blank when the drawings are copied over to another project and I then need to populate the fields. Please advise.
Thanks in advance.
Solved by ccad2509. Go to Solution.
youve stumbled across an issue i flagged up a couple of months ago
if you follow this link
Pat Murren at autodesk wrote a patch to solve this isse
