AutoCAD Electrical Forum
Converting Autocad Electrical to Eplan
4 REPLIES 4
JMARSHALL1249
11467 Views, 4 Replies
One of my customers has asked for their drawings to be supplied in Eplan format.  Is it possible, and if so, how do I convert a project / drawings to Eplan format???
4 REPLIES 4
Gaituuth
in reply to: JMARSHALL1249
The answer is NO.
EPlan is database-driven by its own proprietary database structure.  There is no conversion utility available to transfer from the open architecture of AutoCAD Electrical into the proprietary database structure of EPlan.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
rhesusminus
You cannot export to eplan, but eplan can import DWG-files. However, the drawings will be "dumb" like paper drawings.
THL
Trond Hasse Lie
AutoCAD Electrical and EPLAN expert
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Basically no, but standard layers can be converted to ePLAN layers, however the intelligence will be lost.  This article explains how to convert drawings from DWG/DXF to ePLAN, in the case it is inevitable (For example if a company or department has made the decision to switch tools).  In my opinion it is probably better to just redraw in a other tool.  However, here is the article in case it is relevant.
https://www.bengineer.se/solutions-losningar/dwg-dxf-converting-eplan
”Boost
