AutoCAD Electrical General Discussion
Valued Contributor
galashkina
Message 1 of 4 (166 Views)
Converted to «o» to «x» in the dialog box « Panel Components...»
166 Views, 3 Replies
12-06-2012 12:23 AM
I start the Insert Component (Panel List) command.
In the dialog box « Panel Components...» in the left column displays the «x» and «o».
What command can be converted to «o» to «x»?
rhesusminus
Message 2 of 4 (154 Views)
Re: Converted to «o» to «x» in the dialog box « Panel Components...»
12-06-2012 02:39 AM in reply to: galashkina
If you press the HELP-button in this dialog, the help-file says:
"An "x" displays in left-hand column for any listed panel component tag that already has its schematic component inserted on the drawing and there is an exact match on catalog and manufacturer values between the two. An "o" displays if the tags match but there is mismatch on catalog and manufacturer values between the two."
THL
Please select "Accept As Solution" if this post answers your question. Kudos don't hurt either. ;-)
Valued Contributor
galashkina
Message 3 of 4 (149 Views)
12-06-2012 02:50 AM in reply to: rhesusminus
Can somehow update the database of the project to the "o" was transformed into an "x"?
rhesusminus
Message 4 of 4 (142 Views)
12-06-2012 03:30 AM in reply to: galashkina
I don't belive you can do this amutomatically.
You'll have to go to the components marked "o", and make sure that the Manufacturer/Catalog data matches on both schematic and panel components.
THL
Manufacturing Community
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
