I'm trying to figure out the best way to utilize AutoCAD Electrical and connection interfaces. The following attachment shows the type of device I typically will use on projects. The main control panel would have one, then a secondary control box would have the other side. Then use a 15 conductor D-Sub cable to connect both panels together.
In the past, the drawing would show a 'picture' style view of the device with wire numbers, description and cable #. While this method was beneficial for wiring, it would not show the whole circuit for troubleshooting purposes. I'd like to show the device in a ladder style format instead.
Any and all help is appreciated.
Thank you in advance.
