In the latest revision of my project I have problems with wire numbers. When two wires are connected to the same connection point of a component, both wires gets the same wire number. When I go back to an older revision, each wire number gets a different wirenumber.
Can someone tell me where the bottleneck is?
I have added two DWG`s from both situations.
Solved by Dan_Margulius. Go to Solution.
Dan....
I want to bear your children for this! You have just made my week
This little foible of ACADE has been bugging me for months!
Gavin
Hi Guys
I have the same problem. I changed the settings in the project settings as mentioned above. After this i applied the project settings to the Diagramm, but i still have the same output. one wire number per network instead of the desired wirenumber per wire.
I tried deleting all wire numbers and reapplying new numbers to the drawing and also to the project in a other version.
any other suggestion how to proceed?
greets oliver
