AutoCAD Electrical Forum
Connected wires with same wire number
4 REPLIES 4
929 Views, 4 Replies
In the latest revision of my project I have problems with wire numbers. When two wires are connected to the same connection point of a component, both wires gets the same wire number. When I go back to an older revision, each wire number gets a different wirenumber.
Can someone tell me where the bottleneck is?
I have added two DWG`s from both situations.
Tags (1)
4 REPLIES 4
Dan_Margulius
Please check the settings in the project:
Dan
in reply to: Dan_Margulius
Dan....
I want to bear your children for this! You have just made my week Smiley LOL
This little foible of ACADE has been bugging me for months!
Gavin
Hi Guys
I have the same problem. I changed the settings in the project settings as mentioned above. After this i applied the project settings to the Diagramm, but i still have the same output. one wire number per network instead of the desired wirenumber per wire.
I tried deleting all wire numbers and reapplying new numbers to the drawing and also to the project in a other version.
any other suggestion how to proceed?
greets oliver
rhesusminus
You will also have to draw the wires like in the screenshot above.
That is.. The wires must connect directly to the connection point.
Trond Hasse Lie
AutoCAD Electrical and EPLAN expert
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
”Boost
